pioneer 1200w amp
•MONO BASS AMPLIFIER
•Specifications GM-D8400M
•Maximum Output Power 1 x 600W (4Ω) or 1 x 1200W (2Ω)
•RMS Power: 1 x 300W (20Hz - 240Hz/4Ω)
•RMS Power: 1 x 600W (50Hz / 2Ω)
•Frequency response 10 - 240 Hz
•Distortion < 0.3 %
•S/N ratio > 80 dB
•Bass Boost 50Hz, 0/6/12 dB
•LPF 40 - 240 Hz (-12 dB/oct)
•MOSFET output section
•RCA Input terminals
•Speaker Terminals: Block-type
•Input level control RCA (200mV - 6.5V)
•SP (0.8V - 26V)
•Switchable, LR independent
•Max. current consumption (A/4Ω) 27 A
•Chassis size (W x H x D) 290 x 56 x 200 mm
•Unit weight 3.2 kg
£100
also if u want it in a lupo i will sell the boot build aswell
  • Views 178
will that boot build fit in a polo 6n2 hows the airflow on the amp? and is that a 12" sub?
the build wont fit into a 6n2 as it has a bigger boot
its a 10" sub as well
matt
