6n2 Removing Rear Badges And Wiper
Quick Question About The Badges .
Is There Any Holes Behide The POLO Badge Or Behind The VW Badge ?
How Do You Remove The Rear Wiper ?
( Any Pic Would Be Good )
Thanks ,
Pete
  • Replies 8
  • Views 5k
The POLO badge doesnt have anything behind, comes off easily with warm water and a credit card, just watch the paint and don't use boiling water
Dont know about the vw badge
I'm Mainly Try To Find How To Remove Wiper And What To Do ?
Is It Near Enough The Same As Removing It Off The 6n ?
If So ... Doesnt Seem To Hard :-)
If i remember it's near enough exactly the same as the 6n. Undo the screw in one of the grab handles of the plastic part, prise away carefully, take cap off from the outside, lift off wiper arm, undo the nut, undo the bolts inside and slide out, fill with washer blank... pretty sure I haven't missed anything ;)
Sounds Near Enough Right , Will Give It A Go And Find Out .
Good luck! At first I didn't like the thought of no rear wiper, then a mate came round with a blank and we were bored so gave it a go and now it looks a lot better!
All Done , Piece Off Piss ... Really Simple To Do ,
Thanks For Helping :-)
Thanks ,
Pete
hi I've just removed my VW badge and polo badge and there is no holes, there is just a slight indentation where the VW badge actually sits in.
hope thats helped :)
