1.3 mk2 engine into 1.0 mk2 breadvan.....
hi people, as above really, is it easily done to stick a 1.3 carb engine into my 1.0 carb mk2 breadvan, if so, which engines are the easiest to fit? could i convert to injection easily enough? or would carb be easier to stay with?
any help will as always be greatly appreciated,
cheers, brad :D
p.s, would the 5 speed box also be better or a 4 speed? cheers again...
Edited by brad88
  • Views 938
easiest would be to grab a 5 speed carb'd 1300 mk2 engine ....would be a direct swap , some need the arb swapped to clear the 5 speeder
an injection engine isnt that hard , but more work that the carb engine ...worth it if you can locate a GT engine
thanks mate, thats perfect info,
i think i will be definately doing that then, if its as straight forward as it sounds,
brad :D
hia, did this swap sunday on my mk2 bready, if u know what you are doing can be done ina day pretty easy, was the first time id done it and to take out 2 engines and refit 1 took me the weekend, with the 1300 5 speed, nothing had to be changed, I've got a few extra wires as I've gone from automatic choke to manual but thats it, quite a nice difference between the 2 aswell, much nicer to drive :biggrin:
cheers mate, brillinat info, I've done quite a few engine changes so know what to do, glad everything fits ok, will certainly be doing this now, might need to ask your help at some point tho if thats ok,
cheers, brad :D
no worries, good luck :thumbsup::thumbsup:
