Opinion and pics wanted.
Hey all, I am just awaiting collecting a mk3 polo with crappy steels on it and I have a full set of refurbed 6x13 4 spoke revolutions sitting in the garage for my mini project. Anyone seen or have pics of revos on a polo and will they be ok with wobble bolts. What size bolts do I require and what size rings for the centre to keep them central?
I know the pcd is 4x101.6 (4inch) and vw's are 4x100.
Any advice?
  • Views 1.2k
to be honest mate, as long as you get the centre bore centres properly you should be fine without wobblebolts.
its half a mm deflection each way. Not wroth the money for wobble bolts.
Max
Max
Thats one opinion. thanks fella. Won't know until I can collect it anyway. The guy has lost the keys hence the requests for locks in the wanted forum. Haha.
My opinion is that a thread's surface area is greatly reduced if its not seated square. I'm also of the opinion that a side-loaded force against the bolt head is going to be causing far more stress to the affected side of the bolt shoulder than a centred core load evenly spread all around the bolt. And me thinks that half a millimetre against a bolt with just 1.5mm between the threads is a relatively large measurement..
I would advise against anything less than a perfect centre bore with collared bolts,if running a PCD outside 4x100.00 without adaptors,
Thanks for that. I have read somewhere that those wobble bolts are tuv approved though. Should I read anything into that.
Alternatively could I get the bolt holes in the rim over bored and new press in collars fitted to the wheels or is that too much hassle and cost when I can just source 4x100 rims?
