Upgrade kit for gearbox
hello all, gearbox on the gti is a bit noisy, sounds like a bearing.
i know they have gearboxes made out of the same material as subaru pistons. namely from mr cadbudy.
jsut wondering i've heard people say they do an upgrade kit for the box, is this a VW only part, and also what exactly is involved in the kit as i woud be whizzing the box out myself one weekend and doing it.
any special pullers etc... needed?
Also lightened flywheels, where? what ones best and the same with clutches too what have people found the best?
cheers Gaz
  • Views 819
if its a bearing gone, its just a bearing! have to replace like for like
BUT the upgrade kit if you like to call it, that replaces the rivets in the final drive gear. The most popular gearbox failure is due to these rivets shearing and causing a great big oily mess. The kit as far as i believe is stocked by volkswagen and contains a nut and bolt alternative to the rivets.
The gearbox specialist who did my polo used up rated bearings which are supposed to last longer than the original Vw bearings. There about the best your gonna get or around a grand upwards for a proper strong box
it sounds to me like a noisy bearing to be honest, box dosent feel any different, no oil leaks, just noisy especially in 3rd and 4th gear
