sub not working!
alright so i got given a 250w amp from a friend and my brother gave me his old sub which was working before removing it from his car
so i wired it all up in my car
but the sub is not kicking anything out
when i touch the wires to the sub there is like a little kick or like a noise from the sub for like a second then goes
anybody know what I've done wrong/what this could be?
cheers
jamie
  • Replies 15
  • Views 1.4k
nobody help?
its like it aint been wired right, have you tried the fuses?
also when it hapended to me the amp was knackered so maybe try someones elses amp with the sub or both
Could be the fuses, or the ground or the sub has blown
Is there power? Light on the amp? Check fuses, check the earth. If there is power, check the settings, ie the crossover settings, mono/stereo etc.......as the amp may have been used previously to drive stereo speakers. If they're fine and you have power, then I would borrow a sub and try a working sub. Then move onto borrowing a working amp to test your wiring.
yes i have a power light, but then i have a power light when i dont even have a fuse in so :S proper confused i also have power when i dont have the power lead on the battery :S also confuse me
did you buy the wiring kit new or just take it out your bro's car
when mine was fooked it was the remote wire
do i need a fuse in the wire cummin from the battery and the amp
as now i only have one in amp and not the wire
will this affect anything?
It's a shit sub if it still has a power light on with no fuse!
Ha
My bet is, remote wire..
An inline fuse between the battery and the sub just prevents damage to the sub.
haha well i had it gave me, its only a 240w amp haha
I'm going to have a guess then that even when i dont have power from the battery and i have my remote wire in it still has power that its a totally shit amp
i just tryed a fuse in both the wire from the batter and the amp and it went straight into protect mode so I'm going to have a guess its fucked
is it a two channel amp? if yes why not try the other channel ?
think I've already gave it a try mate going to go round and have another go later
hows it wired?
my mate struggled, like the amp lit up red for power, but only green when it was going to actually work.
it was the earth.
Make sure your remotes working and connected right place.
Have a GOOD earth
Power doesnt need to be fused but will protect it if needs be.
You got rca cable connected to head unit?
Bridge the sub so you get best output from amp
ok ill try checking the earth
were should the remote be going too?
cheers
blue wire from back of head unit (never usually attached to anything)
you can like get a short bit of wire and bridge the remote and live on the amp i think, or somethin like that, but obv the purpose of it is to turn amp off when stereo isnt on to avoid killin batt.
