Any ideas why i have a puddle in my footwell?
was cleaning my car today, and when i lifted my floor mats up it was just completely soaked, water was coming out of the carpet when i pressed it in.
Any idea on this? or how to fix it :/
thanks in advance!
  • Replies 16
  • Views 1.8k
Either the floor grommets missing and you've picked up rain water / the door seals are tired / or you have some metal work rusted through somewhere , maybe around the screen. If you can get access to an airline, then squirt some soapy water around the screen and the doors etc and blow air out from the inside and look for bubbles on the outside.
i think its coming from underneath, would i be able to tell if a grommets missing by jacking it up and looking under?
ye but if there was a floor gromet missing then it wouldnt soak the carpet would it because the water would drip back out?
my old 99 polo used to leak through the door seal and completely soak the passenger and rear passenger footwells
my mate had this on his golf,
check the tubes for the rear washers because there maybe a hole.
Or check around your windscreen, my mate pulled his whole dash out and searched for it, and after a couple hours he found it.
Cant remember what it was but ill ask him.
so its a little mission but better to do it as soon as poss.
Not sure of the layout of the polo but on my old mk1 astra there were vents to drain the heater chamber when water ran off the bonnet which when blocked would cause water to build up and run inside through the heater. So check any drains you can think of even sunroof drains which usually run down to the rear quarter in most cars. Sorry I can't be more help.
I had the same problem on my mk4 polo it used to drive me mad, it turned out to be the sunroof.
Yes either sun roof, OR check the top/bottom of your passenger door black trim for leaks.. iv noticed mine trickling down from just under the speaker pods.
Another one on some cars, especially ones fitted with aftermarket door speakers is that some people cut or remove the thin plastic sheet or membrane which is stuck to the door behind the door card then the water runs down the door and inside the car from the bottom of the back of the door card.
theres no noticeable places where its coming from, just from having a look around with the interior in so basicaly i need to just strip half my interior out and try and figure where its coming from :)
Cheers for help people!
Dale.
Dale.
Do you have a sun roof? If so you need to take the headlining out and check the pipes are clear.
I did it on my mums renault. Took half the stuff out just to find it was from the top! To clear the pipe i just blew down it really hard and all the crap popped out under the car.
Have a look for leaves/crap around the pollen filter - they would block the drain hole and it would run in there :thumbsup:
you have a weak bladder?
Similar to the problem with my Mk1 Astra above then. :)
  • 4 months later...
Rite I've had my car in my garage for a while now, took all the interior out and let it all dry out etc, I've also checked for any build up of leaves around the pollen filter and theres nothing, its not the rear washer pipe because its all dryed out now its in my garage and it still has washer fluid in it. only way i can see water would be getting in is this ...
I take it this is the problem? if so where can i get new bungs for the holes?
Dale.
Edited by Dexy_
anyone? ..
go to VW parts dept :)
