Cannot remove window winders to get to door speakers
Hello there,
So I'm not an expert on cars so please don't ask me too technical questions but this is my car:
VOLKSWAGEN POLO E 2000-2002 1.0 3 door.
One of my speakers has blown out in my right side driver door and so i've bought a new set with a bit more power. This afternoon I tried to get the door panels off with quite a bit of success aside from one silly concept; the window winders! Now I've read up on as many guides as possible as too how to remove them. In most cases for the polo all you have to do is point the winder downward/upward and slide the spacer clip behind it upward for it to unclip and the winder can be removed.
For my car it seems similar, I push the spacer clip upwards and it clicks but the winder does not want to come off at all. I cant see any obvious screws or other clips. I was wondering if anybody else had the knowledge? you know? to get the job sorted ;)
Cheers guys
  • Views 2.4k
Hello there,
Cheers guys
i think the base of the winder slides away from the actual winder bit. opens the clip and then just pull straight of mate hope this helps
For Polo 6n2
Hi Mate ,
Its Like A Rubberish Cover Over The Winder ,If You Feel Behind The Winder You Should Be Able To Pull The Cover Away From The Winder Itself , If You Feel Near Where It Atattched Or Further Up You Should Be Able To Do It . Use Some Force Or It Wont Come Off , Under There Is A Screw And You Should Find You Way From There .
Hope This Helps
Edited by Oldfield1990
ok thanks :) i'll give it a go and get back to you. cheers for the help
got them off and its all sorted. thank you for all the help :)
