OMP roll cages
anyone fitted one of these cages to there mk2/2F?
on the website it says " it may be nessecasy to remove or cut interior pannels to facilitate instilation" this is for another type of cage
was just wondering what pannels these will be and how much adjustment i would need to make to these pannels. and if its the same on this cage
cage in question
any help is much appreciated
  • Replies 12
  • Views 1.2k
Dash board
Where the cold air vents are, these often have to be removed and I think cut away partly.
Thats the only thing that i know of anyway
awesome. is it similar to the cage you are running?
I'm not fussed about the cold air vents. just open the window haha
I think the one I have is an OMP one. Needs quite a bit of jiggery pokery to make it fit.
what sort of things need to be adjusted? I've already got the rear of the car stripped out so no need to remove anything back there.
just trying to guage how much work it will be.
theres no worry about the welding as I've just finished a welding course.
You'll need to fab up the mounting points on the body it's anything like the MKII Golf one but if you're a competant welder you'll be laughing!
nick
ah thats not to bad. just finished my 6 month welding course so i should hope I'm quite handy with a welder haha.
found another one on there for around the £400 mark which is only a 6 point cage. will probably opt for that when I've got money saved :)
paint it white before it goes in should look the nuts
The back went in pretty well but at the front it would need some platforms or soemthing making so it sits right. Because the floor isn't flat on a mk3 it doesn't sit quite right. I would get some pics but atm the car is a shed and full of crap so they would be no use anyway :lol:
If your the kind of person who fannys about with cars yourself and generally a good problem solver you should have no issues. But if your the kind of person who gets stumped if stuff doesn't just bolt in like its supposed to them you might struggle. Thats the best way I can put it really.
haha i like your way of putting that! judging by that, i think i should be fine. will just weld up a mounting plade from 5mm steel plate and weld the cage to that.
all i need now is to get saving!
I've found one aswell thats got removable door bars so i think thats the one i will go for. then wont need to fanny around with having to climb in and out of the car al the time
The door bars on mine are bolt in so I suppose if you were using the car every day you could have them bolted out but then when you were doing some serious stuff bolt them back in. I'm leaving them in though, I know my luck and the day I don't have them in will be the day I get T boned :lol:
ah. what cage are you using?
will probably keep the driver side door bar in. passenger can fend for themselfs! haha
If you're going to use it compete in any actual motorsport check the MSA blue book as AFAIK cages need to be bolted in and not welded in.
Nick
ah right. ill have a look see then. well either way i can still bolt in the cage even if its a weld in type. just weld 5mm plate on the bottem then bolt the plate to the car.
