will a breadvan exhaust fit a coupe?
as in title.
  • Views 1.2k
also are cl exhausts and gt ones different bores?
I usually check on the Bosal catalogue.
http://www.catalogue.bosal.com/pages/index...ve_settings=off
Use public login. Exhausts and towbars europe.
Enter Volkswagen and Polo and 1.3, you get 13 exhausts to choose fromwith pictures of Hatchback and or Coupe.
You can select body type too.
Part 250-242 clamp means it has 42mm outer diameter.
Engine code 3F has a 250-248 rear clamp - 48mm diameter
clamps onto the cat are 50mm
Edited by dvderlm
i have a bread van exhaust on my polo coupe they are exactly the same pal
Apart from the tailpipe being longer for a breadvan...
