Mk1-3 Gaz adjustable front dampers for the very low
Sure theres alot of you out there -90mm down on a mk3 polo and the rides not too good, well these are standard size so fit into a normal strut and the piston has been shortened to suit a 70-90mm drop. Ride quality will improve, and they rebound top adjustable like the coilover units. Brand new - £210 delivered.
  • 3 months later...
  • Replies 9
  • Views 8.2k
will these fit mk2 polo yaeah :p??
  • 6 months later...
hmm bit of a noob, so if i buy shocks and springs...these fit with them?
Toby
You would fit these instead of the front shocks you got with the lowering kit.
They are to improve the ride quality if you are really low.
  • 10 months later...
Can you get some front shocks that are reasonably cheap? Around the 100 mark
  • 4 months later...
I'm thinking off making a set of homebrew coilovers soon..
I'm going to be down 80-90 mm what Lb rated and length springs would you say to use to suit these shocks.
Just looking for something to obsorb shitty roads around here
225lb 6" spring.
Cheers mate
are they gas dampers or hydraulic dampers ?
I am looking for Koni 8641-1215sport that are now discontinued.
Would these dampers be a good alternative ?
thanks
Gas, and yeah I'd rate them on par or I dare say better than the Koni's. Same damper as what is in their coilovers, and they are very good. I can spec the piston length to suit your springs too, they don't have to be for the -80mm...
