6n door handles
Ok my gf's 6n is a nightmare wen it freezes as all the handles freeze up and can never get the key in so out comes the hot water and its fine, the last couple of days haven't been to bad but about 2 days ago the passenger side lock wouldn't turn, the key would go all the way in with ease but just won't turn, now this morning the same has happened to the drivers side, any ideas guys?
Also this is gunna be my car in a month or so and want to get it sorted soon as poss aswell as an issue with it starting sometimes,
Jason.
  • Views 1.6k
Jason.
two options get a central locking kit an delock the handles or carry some key deicer cos its a comon thing to all cars
Dont do that as i did that on my car got a remote central locking kit and delock the handles but the the fuse went and could not get in my car,
Best way is to take apart the handle and spray WD40 all over it i have a never had a problem could always get in to it after that.
take the handles out of the doors, use a hair dryer on the lock barrel to remove any water then put some vaseline on the key or another light grease then put it in the hole and work it abit then grease the rest of the moving parts, this seals the water out of the lock so it cannot freeze!
I just poke the wd40 straw in and fill it up! that way no water can hang about in there and freeze!
But i dont think that there actually frozen guys, as i said the weather hasn't been that bad and the key goes in fine, just doesnt turn?
the barrels could be going??? ebay repair kit needed???
Easy to do?
