steering wheel Boss for MK2
What size boss do i need to fit my MK 2 breadvan?
the steering wheel i'v got has 6 holes if that's valuable info?
any help is appreciated.
Edited by edwardscott_30
  • Views 770
Depends what year it is IIRC. I'm sure early ones have the small spline and the later ones have the large spline. Although it doesn't make a difference cause its only a collar on the steering column that determines the size. If its small spline you can put the collar on to make it large. If it large spline you can remove the collar to make it small.
it's 1990 =]
my mate says i'd have to get a special kind if i want my horn to work in the steering wheel?
thanks for your help by the way =]
