Anyone know how to remove OLD car stickers? -
Okay, i've got an england sticker in the back window of my Polo, It was there before i bought it, and i presume its been there around 10 years+
Its officialy gone hard.. i've tried WD-40, Nail Polish Remover, Soapy Water, Window Cleaner and lots of other random things.
Apparantly your meant to use a Razor. i couldnt see this working with this sticker, as the sticker is so damn hard, and it'd scratch my window if I'm right in thinking.
Any ideas? Pics up later.
Cheers, Zmithyy
Edited by Zmithy
  • Replies 9
Tar remover?
Might work, if you use a razor blade and keep it flat against the window you shouldn't scratch it.
Yer you just need to get it started then soak it in a solvent (I find autoglym fast glass has good solvents in it) you could try vinegar.
As above razor blade flat to the window (this may not be the best idea if it is on a heated screen).
good luck
Edited by cl coupe
I've got some fastglass, tried it a bit
I'll try again later, i've just read aswel, an old credit card is a good scraper, or a ice scraper. i'll give it a hugeee vinegar/fast glass soak, and then scrape.
Hopefully it'll work, just the stickers rockkk solid.
Brake cleaner should remove the glue of the sticker, but not the paint.
i was watching How Clean Is Your House and they said rub mayonnaise onto the sticker, leave for 15mins and scrap off with a plastic card and wipe with a damp cloth.
i promise I'm not making it up, they said its to do with the oils in the mayo that helps loosen the sticker.
Edited by BigSexyRob
well it depends alot on what material is is originally, your best bet is to get a hairdryer and heat it slightly, see how it reacts, it should soften the material and the glue.
If not then yeah you need a stanley knife, if it is a new blade, it technically should not scratch the window, you are only using it to separate the sticker from its glue base.
See how you get on...
I`ve always found the razor or stanley blade work best and easiest.
Seen it as well, they said mayo can remove a 20 year old sticker. Try that.
Got out a new pen knife with a new blade on it and fast glassed it.
The sticker came off in what feels like parts of a credit card.. I think its been there a while
I'm currently slowly working off the sticky residue.
Thanks for the help guys!
