Rust the hate of my life
I could do with some help gotta treat some rust all seems easy enough apart from the bit under the window where it is seems like I'm going to have to get the back window out and have know idea how to do it? Also how much do u think it would all cost if i got it done somewhere I've got the colour coded paint to match so could give that any idea pls help?
post-30188-1264944061.jpg Also before you ask I'm not welsh stuck that on when i went to wales lol
  • Replies 8
  • Views 1.2k
thats nothing amte easy fix! you should see mine!
i wish that was all i had to contend with :lol:
your gonna have to take it back to good metal, maybe use a wire brush attachment on a drill, if it's still bubbled up above the surface you will have to take it back more with some thing like a linishing pad on a grinder then skim over with a little filler, prep then paint.
none of it looks bad enough to have to be cut out but if you do find that any of it (most likely the wheel arch out of all of them) has gone too far then you may have to cut it back to good metal and weld some more in place. other wise it will just carry on rotting under the filler and paint and you will have to do it again in a year or so, might as well do it right the first time :thumbsup:
All seem pretty simple apart from the bit under the back window got no idea how I'm gonna get it out might i have to get the back window out if so i have no idea how to get the window out any ideas?
Edited by sev 101
if i were you i would defo take the window out before starting on that mate. it'll make it a lot easier to work on and less chance of you slipping with the drill and taking your rear window out :lol:
Problems today started grinding rust on arch and found two holes at the bottom would weld them up but mig welders too powerfull on minimuim setting it doesnt help that i had to grind so much off to get rid of rust so steel is very thin now got rid of all rust and just put some primer today as temp measure going back to work tomorrow to finish off. Brought some fibre glass rust filler today do you think i should just use that? pics attached.
Have more pic but will only let me attach two
if the metal is to fin to weld then if i were you i'd just cut it back till you get to good metal, no point in pissing about with filler if you have the welder there to do the job properly. besides the filler will only last until the metal it's holding on it rots away, then your back to square one but with an even bigger hole.
Sorted it out yesterday grinded it back to good steel and fibre glassed it was a big hole so filled it with stainless mesh and put fibre glass on top hopefully i got all rust but there allways a feeling in my head that a little bit still remains find out in a few months when it all bloody falls off lol.
smoothed it down afterward applied primer then paint then laquer looks ok lol would post pic of finished arch but run out of space to upload
Edited by sev 101
