white dials...
I'm looking at changing my dials to white. does anyone know where i can get these from?
i have a different set up to the normal 1.4 mk4. mine has the screen in the middle with the fuel and temp gauges on the top.
Anyone know where i can find these?
thanks
  • Views 494
You can actually make your own, just take apart the clocks, take out the needles with a fork, making sure you lever them out evenly. Then take the clock design off (it's a metallic sheet) scan it into you computer and using image editing software, do what you want and if you want white simply hit the "invert colour" option. Print off and ut out necessary parts and stick it on top of the original.
Can look awesome if you take your time, plus, this way you can add whatever you want on it.
Edited by DubDanny
yeh I've heard about that.
is there anything i need to be specially careful with incase i ruin anything?
thanks
