Just bought a mk3
It's a 1990 'H' 1.0 coupe in what looks a bit like helios blue (did they do that colour on a 90 mk3?) No pics as yet, got to collect tomorrow when I sort the trailer.
Been down there this morning trying to get it moving, the guy lost the keys, so had to pick the door locks to get in (just so happen to have a set of goso lock picks handy, £27 off the net, look em up) and had to change the door handles and ignition barrel to fit the stuff I bought from j60trs from his g40.
Removed the steering cowl and managed to drill out that special place in the steering lock to allow me to pop out the ignition barrel with it still fitted to the car. I was overjoyed when I hit the spot first time and popped out the barrel.
Had to tow the car to free off the brakes and did manage to get it to run for all of 30 seconds with a jump start off my truck until it cut out. Needs a new battery and some fresh fuel as it smells like varnish.
Maybe get some piccy's tomorrow.
  • Replies 14
  • Views 1.6k
Sounds like an eventful evening, lol.
Not making it sound like a nice motor am I. Lol. It is quite a nice motor actually and full of potential. We'll see when I get it home. Drop it, sound nice wheels with a bit of stretch and clean it up a little. It's not been moved for a few years so I shouldn't have expected much really. Fresh battery and some fresh fuel should have it sorted. And it don't look like it'll need a lot of work for the MOT, just freshen up the brakes and give it a little service. :grin:
Right, I got let down with the trailer and managed to borrow one of those solo tow frames which you lash to the lower arms and leave the key in the on position. What can I say, what a weird experience seeing a car that close to you steering around corners without a driver. I have to invest in one of those. 8-)
A fresh battery and fuel tomorrow and she should be a runner so it'll need a clean cos it hasn't been on the road since 2003-4. I was surprised actually at the condition of the car.
Pics tomorrow before and after it's bath. :)
Been up the garage most of the day.
Here's the car,
Crap images and not had a chance to clean it yet.
Fitted a new battery and tried to start it. It will start with some brake cleaner down the carb. I found the pump in tank seized so I took it out and tapped it, and it pumps ok, the problem I have is the primary fuel pump under the car is seized and no amount of tapping it free's it up. So I have a stuck polo.
Does anyone have a fuel pump to suit a 1991 1 litre coupe, I think it is a bosch unit, the one with a cylindrical alloy body and a black plastic cap with two spade connectors on the top.
Cash waiting.
The bodywork seems pretty clean going by the 2 pics.
Check the cars breaking section. There's gotta be at least 1 online pump there.
Well done for not giving up. It'll be worth it in the end ;)
The body is very good with minimal rust and has been parked on the guy's driveway since 2003-2004 so I am surprised that there's not more problems to be honest. I fit's just the fuel pump and brakes to get it on the road then I will be pleased. Been quoted £40 (trade) for discs, pads, and shoes so that's next. After I get it running. Not bad for £100 eh?
Costs so far,
Car £100
Locks £22
Debadged Jom grille £18,
Door armour plates £25,
HD Battery £29 (trade),
Fuel £10
Pump £15 (thanks GenesisGT),
Oh yeah, and my time @ 2 days.
Not bad eh?
By the time I drop the suspension, wheels/tyres/brakes it will be around the £500 mark, I know I could probably get one for £350 but at least I know this one will be right.
Getting stuff at trade prices always helps.
i wouldnt bother with a mk3 the axle snaps in half
Maybe but for the money spent, it's a cheap run about, and anyway, how many on here have snapped their axles?
Well heres todays pics after its bath,
Before,
After,
Looks good i got a mk3 polo not long ago been doing bits and pieces, did the rocker cover gasket today, i have a problem with the brakes though. Because i changed the pads and fluid cause the pedal was crap. The pads looked good but one had been stuck up against the disc. So think need to clean the sliders or new caliper or something.
what a load of bull. I've owned endless mk3s and never had an axle snap!
looks a good buy imo. think the colour is royal met. blue btw
:lol:
haha! I'd like to see you try and snap one lmao. Fool!
My god it was dirty, looks a million times better now its had a good clean though dude.
Ah thanks, I was gonna check the colour code tomorrow to find out. It seems darker than helios so I wasn't sure. My debadged Jom grille arrived today so thats a start. Clear flashers and euro plates once it's had it's MOT.
Sort out the fuel side of things first then I can sort the brakes for the MOT.
code is in the boot, on the back panel. printed on a little sticker (thats if its not worn off)
like i said, I'm not 100% sure on the colour, even though i had one in exactly the same shade a few years ago!
the only other colour i can think it might be is windsor blue, which is very similar
Edited by g40jon
