Bump strip removal
Hi all,
I'm thinking of pulling off the bumpstrips on the sides (down the doors etc) on my 6N, as they're pretty much falling off anyway. Are there any holes underneath them or are they purely glued on?
Edited by BenKoflach
  • Replies 9
  • Views 1.5k
all the mk4 strips i've removed are smooth behind, the 6n2 has holes though.
be careful when pulling them off, i've seen paint pulled off with the adhesive. i use a heat gun and a credit card - begin to pull off at one end heat the 'tape' with the heat gun and slide the credit card along to seperate it as you go.
Olly
Awesome, hoped that was the case. What's the best way of getting any glue residue that's left off it?
I used thinners on my mk3 when removing the strips and it got any remains of the glue off
you can get some of the solvent spray stuff. worked a treat on mine.
not strong enough to damage the paint but makes scaping the glue/gunk off alot easier.
sticky stuff remover from halfords for the glue residue
or you could use a caramel wheel like i did, makes life so much easier did both sides in less then 10 mins :D
eraser wheel!
Ebay
eraser wheel!
Ebay
caramel wheel/ eraser wheel
same difference lol
lol wasnt correcting, you just beat me to it :D
Edited by richoco
