mk3 seats!
ust been tryin to get them out and cant work it out :(
  • Views 1.2k
undo the bolt at the front and then just slide the seat all the way back and lift it up
What he said :)
they are a bugger though, wait till you've got to put them back In again :badgrin:
they are probably the easiest seats to remove once you know how, but if you've never had to do it before it can be a right pain in the arse, i was looking for how to unbolt them for ages before i found the bolt on the lever :lol:
wow its easy when you no what to do! :D
One word of warning, from experience, don't forget to put the bolt back in afterwards. I did once, and adjusted my seat while driving and yes, it came out it's runners, my foot got wedged on the throttle, and I fell backwards, hurting my leg so much I forgot I was driving.
I always put them back in finger tight. That way when you need to clean the car out you can just quickly whip them out without having to go fetch your tools. After all the bolt just stops them coming off backwards for the runners so don't need to be uber tight.
good thinking il do that when the corrado ones are ine!
