Got bbs RZ's, wheel bolts too short?
Recently bought a set of RZ's and looks like the bolts are too short, the tread is only about 10mm into the hub. Where can I get a set of longer bolts, what size do I need? What taper?
Cheers :D
All for a 6N Valver
  • Views 997
i'd be happy with 10mm into the hub, mercedes have longer bolts with 17mm head and the right taper.
Olly
If you go scrapyarding the old C-Classes have 5 spare bolts in the boot with the spare wheel. Always nice to take those ones as they are usually shiney and new and you don't have to pull them off the car.
