Cambering my polo
hey guys i recently helped a mate camber his punto using washers but he had a digram of what washer to use and how many n the studs etc.
we had to put 4 1mm washer at the bottom rear stud and 3 upfront to prevent tow in.
I'm gonna do the same with washers. should i do the same amount of washers on each stud? or like i did with the punto?
cheers
  • Views 1k
You'd be better off using a machined shim.
ahh right ok,
just looking at shims now.
might go for that option rather than pikey washers,
its just i want quite a bit, i want it to be kinda noticable.
and for 20 quid shims you ony get 1.5 degrees.
cheers
shims and washers :D
whats the point in that?lol
i might aswell use just washers ans save myself 20 quid.
