Fitting Bucket Seats To My MK3
i have just bought some corbeau bucket seats and I'm wanting to fit them into my mk3 polo anyone know how i go about it?
thanks sam
  • Views 1.5k
Bolt them to the floor, off the shelf sliding subframes (about £50 each) or make your won with your old seats and a welder.
nick
i'm guessing you haven't got the correct runners to fit them to your car? If not you can either buy some or cut the frames off the bottom of your old seats and weld them to your buckets. Both ways would make them bolt straight in.
Another way would be to drlll holes I'm your floor and bolt them straight in, although they would sit stupidly low and you couldn't adjust them at all :lol:
hmmmm wanting to get the old frames off my old seats but dont know how I'm gonna go about it
Grinder, then they would need welding to your new ones
or bolting.
strip all the fabric and cushions off your existing frames, you can drill out the 6 or 8 spot welds that hold the base of the seat to the subframe, once thats done chuck that away and weld two bars onto the subframe that match the distance of the mounting holes on your bucket seat, drill holes thru the bars and get some studs on the base of the seat holes, line studs thru holes, bolts and your away
make sure you use high tensile bolts and nuts and have a decent weld between your box section and original subframe
I dont think you can bolt seats to the floor in a mk3 as the floors too unlevel.
