help with my car
hi there, i have a 98 (r-reg) seat cordoba cupra sport, does anyone know what they class this model as, I've seen parts advertised for a cordoba k or a cordoba k2 ect, also i know its the same as an ibiza gti but does anyone know if an ibiza rollcage would fit in it as the inside should be the same up to the rear compartment where the cage ends? any help would be much apreciated
  • Views 850
The cordoba is the same as the Polo saloon or Classic which is a 6k chassis I believe.
Dunno where they get the k or k2 from unless they mean the k2 as in the 6kw variant wagon thing.
it was th 6k thing i was meaning, thanx for that, i presume that as its a 2.0 8v it will be the same as a golf gti engine, are parts available the same for the engine such as manifold?
Check out seatcupra.net, theres a cordy section on there which might help you out :thumbsup:
