Wobbly seat!
Hi, i`ve got a 2003 1.4 tdi sport polo and the drivers seat rocks back and forth, is this a common problem? Is it easy to fix? Parts expensive?
  • Views 1.3k
pull the seat all the way forward and check if its left one or two plastic pieces on the runners,if so then thats the problem
they come away hence the wobbly seat
thanks for the info, both plastic bits are broke. Does anyone no what i need to fix it and if so where i can get it from?
They're called Outer Glide Pieces mate,the part number is 171 881 213B and they come in packs of two.
thanks buster.g40, is that a vw part number?
