engine bay cleanup/paint....HELP
hello..
I'm looking to paint a few engine parts (rocker cover,alternator,starter motor...etc)
has anyone done this and how did they do it??
any help would be cool...and pictures if possible! cheers
any help at all would be great?
Make sure all parts you want to spray are grease oil ect free then rub donw and paint the colour of your choice. Remember to use heat restiance paint on the rocker cover
cheers for the advice dude,my friends just done this on his g40 and the paint seemed to melt after 10 minutes??
I sprayed my exhaust manifold heat shield, 6 months on its flaking off like crazy but when the paint is only 6 quid a can i guess thats not too bad.
As above, make sure you use heatproof paint. Halfords do a selection- i went for the very high temp stuff to be in the sure side. Left a powdery finish tough.
for the best effect your best taking them off, give them a good clean and give them a rub down till they feel smooth, give the 2-3 coats of high build primer, leave it to dry then wet flatten with 800 wet and dry, clean them off, spray a minimum of 3 coats of the basecoat paint onto whatever it is your are doing then add 2 coats of HEAT RESISTANT lacquer to stop and flaking or bubbling with the engine heat
really if you want a good finish of any engine parts and plastic etc you need to treat them like you would treat a panel on the car so as to end with the same finish
