how do i remove rear seats mk3
i know its probably the simplest thing ever but can someone tell me how
  • Replies 9
  • Views 1.4k
the bottom bench is just held in by 2 big screws and clips. then the back bit slide's out, miight be a bit tricky to get out. then all the belts are just 17 mm bolts.
Somone asked this a few days ago. Do a search its all in there.
i did do a search couldnt find it, so just un screw them 2 big screws? they were pretty stiff when i tried and is there going to be a bolt on the other side of them thats gona drop through or anything?
nooope.
Just two big dirty screw. Bit shit tbh.
Try gettin a small stuby driver or ratched with phillips bit in the end if its too tight for you noodle arms :)
Just kiddin.
haha noodle arms :p
thanks man
pleasure dude.
you dont need seatbelts to pass the mot to you if you aint got no seats?
hey dude i did this to my mk2 coupe other week,
was dead easy just 17mm bolts everywhere and the seats were just the screws,
only problem i had was the 2 seatbelt holders in the middle lol bolt got stuck an then wouldnt turn in or out but a can of wd40 and a big friend later it was out haha
nope no seats no need for belts :D
