aftermarket h/u wiring, no plugs behind dash....
trying to fit my aftermarket h/u into my mk3 polo coupe, only problme is i just have wires behind the dash, no plugs,
i have some iso plugs ready to be connected but not sure on what goes where,
behind dash i have these wires
BLUE/GREY
BROWN
BROWN/RED
BLUE/WHITE
RED
RED
BLUE
BROWN/BLUE
BROWN/WHITE
on the headunit i have
YELLOW
BLACK
ORANGE
DARK BLUE
RED
WHITE
BLACK/WHITE
GREY
GREY/BLACK
please could someone just point me in the right direction, any help will be greatly appreciated,
cheers, brad :D
  • Replies 14
  • Views 1.8k
you should have purple and green on the head unit too their for speakers lol what headunit you got??
BLUE/GREY = illumination connect to orange on stereo
BROWN = earth connect to black on stereo
BROWN/RED=ignition key sense not needed
BLUE/WHITE=speed pulse not needed
RED= permanent 12v supply (check with a meter first) connect to the yellow on the stereo
RED= as above
BLUE = aerial remote connect to the amp remote on stereo
BROWN/BLUE speaker negative
BROWN/WHITE???
YELLOW
BLACK
ORANGE
DARK BLUE
RED
WHITE front left speaker +
BLACK/WHITE front left speaker -
GREY front right speaker +
GREY/BLACK front right speaker -
cheers, brad :D
ammended for you
you will also need to run an ignition live from the rear of the fuse box or steering column to the red wire on the stereo
the cars ignition live will be a black wire
so if u get a feed from the igntion and connect to the black on the head unit it should work ?????? i hate wiring :@::@
Edited by vw-nay
no the black is the earth connect this to the brown wire on the car
you need to run a feed from the black on the ignition switch or the rear of the fuse box and connect this to the red wire on the stereo
ok I've theres a black on the ignition that gos to my imoboliser can i get a feed of that
yes you can
theres a brown with red stripe wire coming from the ignion I've tryed connecting it to that but no luck and i carnt find anywere to get the feed theres like 8 black wires :@
could i get a feed from the black wire to the cig lighter cheers
i did tell you not to use the brown red as that is just a key sense and the stereo will not work with the engine running off that
if the cigarette lighter only works with the ignition on then yes you can use that
i dont no if it work its all taped together some cowboy hs done the immboliser its all wires everywere sorry to be messin u about pal ime shit at wiring dont have a clue
sorted it all just no sound the speakers have had it so ime gonna get some new ones :D
got it all workign, cheers, only problem is, where do i wire the drivers side speaker upto? got the passanger one wired up but where do i put the drivers side wires? as soon as i put them anywhere the passanger speaker starts to go fuzzy,
cheers, brad :D
the drivers side speaker need to connect to the grey and the grey/black wires on the stereo grey is + grey/black is -
sorted it mate, cheers for that, it connected to the brown/white and red wire,
cheers, brad :D
