MK3 Heated Washer Jets
Right, is this just the case of wiring one wire to ground and the other to a switched live with an in-line fuse?
  • Views 744
Popular Days
feed is the black 1 pin connector below the fusebox inside the car. its within 3" of the fusebox so cant miss it.
the earth is the white 6 pin T shapped connector with in a foot of that (4 spaces for connections on the top & 2 on the bottom) where most of the dash wires earth too. :thumbsup:
Edited by genesisGT
