Interior Swap
Hi,
I got a polo 6n with the light grey with the coloured squares interior and i wanna swap it for maybe some half leathers or black cloth. But I've noticed that alot of the inteior swaps u can do, have split rear seats and mine doesnt have a split rear seat its just a one piece bench.
Does any body know if u can modify it so u can put split rear seats in it ???
Also can/does any one know what door cards will go in 6n either straight in or with minimal mods on 3dr btw
J
Edited by James Boi
  • Views 1.6k
Yerr you just need the little bracket that bolts under the seats can be found on any 6n bar the L
would you need to drill holes in floor to fit this bracket to a L or are they there anyway ?
Gonna do same so curious.
Mark.
  • 5 months later...
i need some help can you explain in more dtail please as i am now stuck
Mark.
the holes are there already just need the said bracket and three m8 bolts :-)
As stated...get hold of the little bracket that goes in the middle of the rear seats, this allows you to attach the rear split part. guessing the bottom part of your rear seat is split in two already, though if not you may have trouble mounting the split seat as it uses a metal hook on either side to attach to the chassis.
if you need the bracket, let me know as i have one in my old chassis...also I'm currently selling a set of half leathers ;D
