doorcards breadycoupe?
will door cards from a mk3 bready fit in a coupe?
  • Views 773
Front yes, rear no.
no and yes as Kam says but regarding the rear ones.....
coupe to heck is a no no as there isnt enough material as hecks have a longer pillar. But you can and i have fitted heck rear cards into a coupe. but you need to lift the material back where the seat belt goes behind the door card on the pillar then you need to sit with a stanley knife, pencil and ruller or bit of cardboard for a template and trim the backing to the right shape then stick it back down. takes an hour or two. but it looks fine when your finished. :thumbsup:
or you could say no forget it and go out get laid that night instead! :lol:
Edited by genesisGT
i have some MK 2 back doorcards if you want them?
