calling all mk2 and 3 owners with door speakers
iv got a simple question where did you run your door speaker wires?
as i have a hole in the door but not on the body and i dont want to start drilling holes as water might get in.
so have you drilled a hole or found away of getting the wires into the car?
  • Views 671
Popular Days
You can just see where I drilled into the door jam if you zoom in, there a hole in line with that on the door that I also drilled. Both holes have gromets and the wire has enough slack to bend. No leaks:)
