front number plate recess smooth over?
will i be able to smooth out the recess in my front bumper just with body filler or will it be to thick???? many thanks for help :-)
  • Views 986
filler will sink,swell crack etc, you need to plastic weld a panel in there, you can cut the panel you need out of the canter of the upper rear 8v bumper!
Defo dont use filler. As Pepe said plastic welding is the way to go.
