6n2 drivers electric window fault
i have just bought a 6n2 1.4mpi and the drivers electric window wont open. but when i use the passenger window switch on the passenger window goes up and down i then leave my passenger window half way down and use the drivers switch and it goes up but not down. i then use drivers swith for drivers window and nothing happens up or down but when i press up i hear a clicking on the drivers window and same clicking on passenger when it is fully up usin the drivers switch.
much help grately needed please
tom
  • Replies 10
  • Views 23.2k
tom
I have a similar problem. Have a look at the wires within the rubber casing between the door and chassis. It's likely there's a broken/damaged wire in there. You can peel back the rubber without damaging it, although it is a little fiddly!
Having said that, I can't spot any broken wires in mine, therefore my next step is to remove the door card and check the remaining wiring.
it is possible that moisture has got into the switch.
although, you can try giving this a go:
-insert key into drivers dor, lock and hold in place for ten seconds,
-then unlock and hold for ten seconds, windows should open
-hold both drivers side switches in the open position
-then in the closed position
-repeat on passengers side.
if this fails, then you would have to remove the doors panels and have a look at the wiring / mechanism.
hope this helps
hope this helps
Thanks for the replys just tried those tips on my brew now and no joy so on thurs a auto electrician is coming out to have a look at it and hopefully i will have it sorted if not i will put manual window mechs in and door cards out of a 1.0l 6n2 and by pass the sun roof sum how
Tom
hope this helps
Tom
Hello mate, i'm having the exact same problem - only my electric mirrors and central locking switch aren't doing anything either - did the auto electrician find what was wrong with your motor?
Guinness
My driver side window switches stopped working the other day, they've been fine up until then. My passenger side window switch is still working as it should. The passenger switch on the driver's side... you can still hear the motor for that one, but can't hear a motor for the driver window at all. Fuses look fine, and wires do too.
I'm going to try what has been mentioned above, take off the door card, and if i fail will speak to an expert :D
right sorry for not replying... u will have to go to VW them selves for 2 new switches for the drivers side part number V6X0 959 855 B0 1C 020F03C SWITCH at £17.28 each.. this should hopefully cure the problem if ure regulator aint dead but as mine was then i had to pay £30 for a 2nd hand one then there is the case of gettin the glass down to put the new regulator in... trick is undo the 6 torx screws on the motor and wind the armicher this will only wind the window down not up
if peeps get stuck i will dismantle mine tomoz and do a guide
tom
Hey,
I've got exactly the same problem but the passenger side does not work. Seems to decide when it wants to work.
I took my door card off, looked aat the motor put it back together and it started working, than stops again after about 4 goes with it up and down.
so was wondering sound like the motor is on its way out?
cheers
Jordan
Seems a common problem.
I have just got a 6n2 gti and the windows go down on both sides but the switch for passengers doesnt work on my dirvers side.
Any ideas people???
iv had the same problem on my 6n2 gti, first time got switch replaced workd for a while then dead second time got pissed off so jus left it started working again, 3rd time replaced switch again went off a month or 2 later now when it dusnt work i give it a bit of a thump and it works :) happy days
i have a similar problem where the switch for the passenger window on the driver side doents work all the time. it seems to work on warmer days or wne i push the button really hard. the garage was gonna replace the switch but they ordered the wrong one. i might take the switch out and have a look and see about getting a replacement.
how do i get the switch out. my car is a x reg 6n2 match
