Leaking?
I had my car cleaned the other day and on the way home the passenger side of the dash was leaking water, the car does smell quite a bit so i have come to the conclusion that its damp.
Does anyone know where or how the water is getting in? as I'm guessing down the line the floor pan may need to be replaced.
Jack
Floor pan should be fine if you get it dried up ok :)
Look around the pollen filter in the scuttle tray, if its full of leaves and crap then it could be bloacking the drainage holes - forcing the water to come in :thumbsup:
Could also be door/sunroof seals :)
good be leakin through the windscreen seal to bud because my mates bora done that so check that to bud :-)
When i bought the car it was full of leaves around this area maybe i've missed a few ill give it another look.
good be leaking through the windscreen seal to bud because my mates bora done that so check that to bud :-)
At the bottom of the window the is a slight gap in the plastic that goes along maybe this could be it thanks mate.
it could be worth lifting the carpet up as i had the same problem lifted mine u and found some big rust holes straight through - caused by some previous owner not jacking it up right. temporarily fixed by metal plates siliconed on (need it welded lol) e.g:
passenger side
drivers side
I sure hope not haha, but the water is actually coming from the dash not the floor itself. I just don't know where to start with it, overall conditions good its only done 41,000 miles which is good just has some rust and a few niggles.
thanks
Jack
