Be careful with wiring
My mate and I installed remote locking kits into our cars a month ago. I insisted on soldering everything and he insisted on using crimp connectors. A week ago his car kept getting a flat battery overnight until it decided to die altogether on thursday and it won't budge(everything's pointing to a fried ECU as we can't connect to it with a vag com). We kept charging the battery since the gauge in the instrument panel was showing that there's not enough juice for anything, while readings taken from the battery itself were very healthy. He then started to take apart the dashboard and everything below that, to see why the gauge was showing a false reading. He soon found the reason:
His shoddy wiring had melted part of the relay plate(well one of them, he has an Audi A6 and it has relays in every hole) and a good solid part of the insulation of every wire around.
I took apart my wiring in panic and found that it's solid!
  • Replies 9
If you dont use the right ampage item then that will happen. what the hell was that wired too? as its pulled a fair few amps.
I've seen people using blue 5A connectors on things like foglamp circuits.... when i fitted the extra charging cable i went to an auto electrician to make sure i got the right bits, he said think how much will be running through it at peak use and use the next size up just to make sure.
Edited by Cymro
Hmmm, you appear to be slating crimps here, theres actually nothing wrong with a crimp if used properly. I use them all day for 400v 3 phase AC systems, often in harsher environments than a car. Never ever had a melted termination like that on one of mine, or anyone elses for that matter, crimp joints. I would and do trust a properly made crimp with mine and my colleagues lives on a daily basis.
So, why did it happen? I'd look more toward the following:
a) Incorrectly sized crimp - The crimp should fit snugly around the wire, the wire should not need doubling back to fill the terminal. Badly fitting crimps cause high resistance joints, creating heat, which in turn increases resistance, which increases the heat further, increasing resistance, and so on.. Also, ONE CRIMP PER WIRE.
b) Uninsulated crimps - Ideally an insulated crimp should be used, failing this, I would use some pvc sleeving or insulation tape. This will prevent + to - faults and arcing which creates heat.
c) Wet joints - They will cause corrosion of the terminations, this leads to high resistance joints and the problems discussed in (a). This can be prevented by spraying with wd40 AFTER the connection has been made and tightened.
d) Incorrectly sized cable - Cable should be selected for current carrying capacity and volt drop. As a rule of thumb, the cable you are using should be of equal or greater cross sectional area to the cables already connected to that terminal.
e) Bad maintenance - Although a correctly made crimp is a maintenance free joint, the lug end is not, bolts and screw terminals should be checked regularly for tightness ans signs of high resistance, e.g. burning smell, corrosion, heat, buzzing/crackling etc.
Although your mates connections are burned they don't appear to have touched anything else, burned connections don't fry ECUs, short circuits do. That might lead me to question the integrity of the circuit design, and/or to look for short circuits elsewhere which may have allowed too much current to flow through the above connection causing it to overheat.
Again I cant stress enough how safe a properly installed crimp is. If I trust them for 400v then 12/24v should be a breeze.
This rule should be applied to the cable first, the crimp should be sized correctly physically as well as by rating. But yes you're right, to add 20% tolerance is an ok rule to go by.
didnt bother with saying that as we were on about crimps :lol:
bit like connecting fogs/driving/grill lamps by piggy backing off straight off the headlamp feed, its never a good idea, but a lot of people seem to do it despite the apparent risk of melting wires and the resulting car fire. Is it really worth the risk over spending a few quid on a relay and doing it properly. hell halfords sell a kit with everything in it for £13 odd.
I just felt the need to add it as many crimps aren't rated, they are just of equivalent cross sectional area to the cable that fills it's opening.
People may also misunderstand and put massive crimps on skinny ass cable. I'm not pulling you up on things, just putting it in uber simple terms as many people don't have the first idea when it comes to electrical. Just like me with mechanical! :lol:
Edited by danny6n
I think it was a) that happend.
I'm not slagging crimps as they're used plenty all over the car, by the manufacturer. :-D I'm slagging my mate who did it with crimps and they were rather badly fitted. Lets say his approach is usually quite...hammerish. If he could bash wires together with a hammer, he would. I'm much more comfortable with splicing and soldering wires, so that's why I insisted with that method.
As for what it's wired to, no clue. He was sure it's the right thing, it is a constant source for power, so it works with central locking, but dunno, I wouldn't go messing with wires without a Haynes at least.
I made up some loom on the weekend for my vdo gauges and felt like the only person who has ever used a relay and ran separate new power and ground wires for them instead of piggybacking straight into an ignition live behind the dash. I need the peace of mind though - every time I see a burnt-out shell I remember how easily it could all be lost!
While electrical stuff is what I feel the most confident about on my car, it's also the thing that scares me most if it goes wrong - you'll lose everything.
Soup, soup, a tasty soup, soup
A spicy carrot and corriander
[Chilli Chowder!]
CRUTON CRUTON
Crunchy friends in a liquid broth
I am dispatchio, oh
I am missala soho.
Misso misso,
Fighting in the Dojo,
Misso misso...
Oriental friends in the land of soup
Oh wait, wrong type of crimping...
hahahaha I <3 that episode
