Smoothing Boot
One of my mates is wanting to smooth off the badge, and number plate on a 6N boot, and has asked me to get some metal cut to the shape thats required.
basically its a question to people that have done it before, i was wundering what thickness sheet to get cut? because if its too thin it will blow holes in the plate, or too thick it could blow holes through the boot.
So what have other people used? personally id say 2mm, but my mate thinks 1.2mm thick sheet will do the job
Cheers for any help
`Shack
  • Views 997
You want one thats roughly the thickness of the plate recess, 1.2mm wil be too thin and warp like mad when it gets wded. 2mm isnt much better,
what do you recon then? can get anything up to 25mm cut if needs be
anyone?
Got any feeler gauges (think there called!)? Nitromors all the paint off the spare boot he has and then put a spirit level across the plate recess then slide the feeler gauges under it until you can get a thicker one in there! Then that's your thickness!!
