Mk2f Coupe, Under Its Second Restoration!
A better picture of the bay at the moment:
  • Replies 1.1k
  • Views 120.7k
looking well bud i wouldnt mind power like that from mine
I'll help you build up an engine if you want matty?
If i you were gonna do it, its i would add a ported head, made a big differance on its own on my last engine.
ported head it is then can you do em or did you send yours off
I did mine over a few days, more "smoothing" that ported. Anyone can do it with a bench, dremmel and emery paper.
dont have any of those things ill pay you a visit in new year and we can scan over a few things meanwhile i found this which you may like
I know I'm not allowed in here but i thought id stop by and show some love.....
So whats actually happening on this? Gettin as bad as tobys thread haha!
Faaak, that sounds sweet.
GT engine, plus weber and highlift cam = Epic noise. Better than any AFH tobes 8-)
Scrapping it bro! :lol:
Well, be using it for a few months yet. then robbing some much needed parts from it then break the rest and scrap.
Dunno what to do with those Calipers now... might just keep um as spares or something.
Not worth selling with no seals etc, but not worth selling after fitting new ones either really :lol:
Whaaat? why are you getting rid of it?
Oh and no 8V will EVER sound better than Doms Dragon green 6n did.
Wait and see 8-) , what was it running?
yours sounded sweet at action max even though it was kicking out oil lol cant wait for this to be done its going to be epic and the noise will be proper dirty if it sounds like that mk2
by the way when you want to put the engine in give me a shout ill glady come help
Lol, that was the fried piston rings on cylinder 4. I did a compression check on the engine when i got back from action, 150psi on cylinders 1-3 , 40psi on cylinder 4 :lol:
It may be a while untill i drop the engine in, got the bay to sort out too!
A moderate update for you all....
Spent a few days over the Christmas break in my workshop. In the quest for a compression ratio of around 11.8:1 - 12:1 (Big i know, will be running it on high octane fuel)
I worked out that i'd need to remove 2.1mm of material from the pistons and block, to get the original compression ratio of 9.5:1 upto the above figure, this is also with the valve pockets machined back in to allow for the high lift newman. See the link a few posts above for more information on the topic...
A few pics of the work;
Pistons, block and rods before work carried out;
Cleaning pistons
Milling block
Pistons and block after machining;
Gonna hopefully be buying a full set of pistons rings of arun, checking the shells with plastigauge and hopefully re-using them.
Slightly aroused by those photo's. Keep it coming!
Beautiful.. Moar!
:lol: Your always aroused. You'll love whats coming next!
Beautiful.. Moar!
8-)
Nice :-D , you going Rolling Road day?
Cheers dude, will hopefully be going, don't hold your breath though...
this is awesome! this is a proper engine build... i crave more...
Just tryed picking up the cylinder head, forgot it was at 300*c and just come out of the oven :shock:
Ouch!
you pleb sir :lol:
Valve guides out 8-)
A few pics of the finished custom pistons, still need to be smoothed mind....
And the stripping of the car...
good progress! keep it up!
Clean? :lol: Shes a right mess dude, Gonna be fully stripping the bay so i can do abit of smoothing, cleaning and re-painting.
Full plans are on previous page IIRC.
Think she needs a new offside wing though, a mix between a bad repair on the lower part and me being very rough on it during removal,
Everything else, (bonnet, other wing, front, doors , rear quarters, roof and boot) will be resprayed, by me as i'm not that bothered about finish quality, i'll do a good enough job for me and thats all that matters
Engines hopefully gonna be abit of a monster for a 1400cc 8v...
i'll try :crybaby:
