Mk2f Coupe, Under Its Second Restoration!
Yeah it will be the pilot tube method, i've read that the boost pressure must be referenced to above and below the diaphram too?
  • Replies 1.1k
  • Views 120.7k
I love carbs. More airflow draws more fuel. FTW
Just had a look on eBay and they sell for stupid money, its going on carbs not EFI.
I think the linear boost maybe more suited to getting the bike carbs to work.
What RPM does the G40 hit maxmaxmaxmax boost with toothies?
G40 will hit peak boost and hold at circa 2-3k depending on cam/head spec. May see slightly higher boost by 7k as the VE of the motor drops off.
Toothies don't gain you any power over a 65mm pulley, they just mean you don't have to worry about keeping v-belts covered in belt dressing and nicely tensioned to maintain consistent boost.
What ignition system is planned?
That's what i want, instant boost. Didn't think it would be as soon as that though!
Scroll type chargers are very efficient too aren't they?
Ignition system, hmmm, looking at the other simular builds, the boost referenced vacuum can and standard distributor have proved to be adequate, so it might be that at first, then once its running well, i might look at getting something that is mappable,
What would you recommend/suggest?
Megajolt is pretty easy to install and work with, fitted it to my friends fiesta in conjunction with bike carbs, works well. But IMO the effort for that I'd make a little more and go full EFI
What does the kit consist of? It would work even better if your adding a charger i'd guess, as any error in spark timing would have a much more drastic effect!
You kinda build it up to suit, his being a ford it already had half the wiring and sensors there.
But it's trigger wheel, loading (we used the CBR throttle position sensor) an EDIS unit, coil pack, ECU and wiring. Runs on wasted spark.
We tried to run his on the standard management for ignition using the ford TPS on the carbs and it worked. But putting the Megajolt on absolutely transformed it, would probably leave my mk3 for dead. Only a 1.6 16v
Wasted spark be ok with boost?
I'll be using CBR600 carbs just because there covered well and have the TPS there already.
This will be an after project though, once i've got it running properly on the standard dizzy and vacuum can.
http://retrorides.proboards.com/index.cgi?...p;thread=134939
Seems cheap as chips to me
£125!! Might fuck the dizzy off all together, it would cost that for all the other stuff!
Would it just be mapped accordingly for when it comes on boost?
Phone Aldon automotive. At RR day they said they'd nearly finished their mappable ignition which would work with a dizzy! And built in limiter/immob, and not expensive!
megajolt is so easy to use and set up. we did it to ollys old mk3. aldon will set it up aswel as they tweeked it at the RR day 2 years ago.
Plenty of base maps available for megasquirt so I would imagine the megajolt would be the same. Plus who wouldn't want to be able to plug a lap top in and adjust shit?
They even have forums dedicated to megasquirt so I'd imagine these would either cover the megajolt or that may even have its own forums. There's a hell of a lot of info and help on the net for them
The Megajolt has a folder full of ignition maps with the software. There was one for a golf 16v which didn't look far off my flat dizzy curve at its low load map. There's info out there, you can even measure your standard dizzy to get an idea first.
If you do want some bike throttle bodies max let me know as I have some sat in the garage I was going to use but not going that way anytime soon and will let them go cheapish
Using carbs dude, but thanks anyway pete.
Megajolt does sound like the way to go then, I'm just wondering about how it all works for when it starts coming on boost.
Trigger wheels sell the kits, drop them an email, I have found them pretty helpful in the past
It would use a map sensor max
Instead of a TPS? Just looking on the website and it says you can choose between TPS and MAP ECU's
http://trigger-wheels.com/store/contents/en-uk/d45.html
About £300 all in, need an EDIS though
Edited by MaxGT
Tps is no good for boost because the throttle position doesn't tell the ecu if its boosting or not
So yeah map instead of Tps :thumbsup:
Edited by Mclovin
Yeah as guy says, you want map for boosted engines, I just used the TPS as an example :)
Yeah i understand now, throttle position wouldn't have the direct link like it does in a NA engine,
That one on retrorides was at a very good price, but they go for like £300
Might be worth keeping an eye on eBay? Get one without the sensors and buy them separately to save monies. Buying a map sensor from omex is like £85 but on eBay the same 3 bar map sensor is like £35, even cheaper if you buy second hand ones
someone got a bargain with these, well gutted but didn't have enough in paypal to chase them any higher
http://www.ebay.co.uk/itm/200805619909?ssP...984.m1438.l2649
but it proves that buying the sensors from ebay rather than in the kit could bring the cost of a megajolt setup down considerably :thumbsup:
