Mk2f Coupe, Under Its Second Restoration!
Why can I find no mention of it then? I'll have to look in my other manual and see if its in there
  • Replies 1.1k
  • Views 120.7k
thats books for you!
the silver coupe i had also had an HK
They came in the early mk2 Polo coupe 'S and early Mk2 Golfs
The manual your looking at may not go as early as the solid lifter engines simon?
Anyway, less chit chat.
It does and I have mk1 manual too. Hmmm. Anyway, as you say, SHUT UP!
Might aswell keep the progress of the mechanical engine in one place,
Ordered;
Main bearings
Big end bearings
Head gasket set
Big end bolts
Have;
Head bolts
Pistons rings
Need;
New guides & seats :-(
Good progress Max, cant wait to see it been re-built
Ill send you all the links etc, where i got the best parts for the least money 8-)
Did you find the manual mate?
Ooh, can i have links too please max.
Did you mean seats or seals? Are you going with bigger valves?
Seats, new guides means you HAVE to re cut the seats. Otherwise they may no longer be concentric with each other.
£75 the work though, not too bad.
Need to work on the inlet manifold aswell, and buy the cam!
Re-cut? I get you. I thought you meant getting new seats installed
No! I wish :lol: i wouldnt be sticking with the bottle top valves!
Still need to do these calcs!
Ordered;
Main bearings £25.50 http://www.ebay.co.uk/itm/300744256267?ssP...984.m1497.l2649
Big end bearings £38.53 http://www.ebay.co.uk/itm/271087532055?ssP...984.m1497.l2649
Head gasket set £13 http://www.ebay.co.uk/itm/190662993296?ssP...984.m1497.l2649
Big end bolts £36 (Off lupoboz on here)
Have;
Head bolts (GSF) £11
Pistons rings £80 (Lupoboz off here)
Need;
Well, i said i needed to start work on the inlet manifold side of things, so today's lunch hour was a productive one...
As can be seen, the port flows from the oval shape of the head, into round 8-)
Edited by MaxGT
Also, the main bearing came already! cheers GSF!
Thats sweet as! you'd mad a shit ton of money making those for people with bike carbs! I'd buy a set :)
They're piss easy to make tbh, that took me about 20mins, 10mins of that was programming! the fact that the cross section changes shape through a distance of 20.5mm was the only tricky bit.
They wouldn't be cheap though! :lol:
I'm going to be makin my itbs manifold that way Out of solid so much better looking and stronger ;)
Tell me about it. Much better!
Pics of fitted;
How much isn't cheap?
It does look great mate guessing your making 4 individual ones yeah
How much does it stick out and the carbs will be bolting straight to it yeah
26mm the boss protrudes out,
Yeah theyll be 4 obviously, and the carbs will be joined using reinforced flexi tubing, simular to what mikey used...
You're so gay! That looks lush. Why not get some bike carb rubbers and machine a groove into the boss? The bike rubbers are immens, hold mine rock solid. Or are you going to use the tube to extend the mani too? That lenghth ought to be good for low end grunt
Do you mean high end? :lol:
Nah, not gonna be using the rubbers, you'll see!
They will be extended though.
These are juat to get the port matching done properly...
