Willwood 239mm 4 pot brake conversion
Willwood 4 pot brake calipers and brackets for use with 239mm discs on a G40
£350
  • Views 425
Are any modifications required to fit these, or do they fit straight to the hub carrier?
Performance-wise how do they compare with fitting larger OE brakes such as a 256mm VW/Audi caliper?
Are they new or used?
Thanks.
my mate is lookin for some but 256mm, got any phil?
Do these fit behind a 13inch wheel then? :paranoid:
And any idea of the cylinder size as I'm curious about, if fitting these would cause longer pedel travel.
Edited by max_crox
pics
