Dewipering a 9N
Quick dewipering question - I have taken off the nut that holds on the rear wiper on the outside. There is this black piece that holds on the wiper and is attatched to the mechanism on the inside - however it seems to be stuck and i cant remove it. Any ideas?
I need to remove this part to remove the mechanism at the back, so any help will really be appreciated.
  • Views 806
I'm not the most patient person in the world, just got the wee grinder out and cut it off! :evil::badgrin:
Good tip for you, get a hard bung to put in the hole and put a wee bit of black silicon around it once you put it in.
Undo the nut, pull of wiper arm.
Open boot. located screws holding boot liner to the boot door, undo and just give the liner a good old pull.
You'll see a further 3 screws holding the wiper motor on, undo these, remove, be sure to plug the washer hose.
25mm bung, bit of grease on the back so it seals, bam your done!
Cheers for the help guys. Know how to do it, just the wiper arm isnt budging with the nut removed :(
Got my 25mm grommet sitting waiting haha.
