Almost There
I have an '89 Breadvan polo, she has harlequin colors, i have no pics yet cos i'm a douche and keep forgetting...
I bought her last september and since then i have managed only 2 weeks on the road.
It was an eventful, dispiriting, scary and downright dangerous experience.
On one particulary rememberful journey to Liverpool, i think she weaved, bucked and left the motorway so many times i decided enough was enough and parked her on my Mother's drive.
In the past my mother's drive has been a kinda car graveyard.
Many a car both me, my 2 sisters and my dad have bought at different times have stood motionless, desperate and on the way to rusty junk.
I suppose at the back of my mind i thought this would be the same, but somehow this time things are different.
The money, time and effort mostly other peoples have been spent and she's almost ready for the MOT.
Sadly last weekend, i changed the plugs, leads and filters and now she's only firing on three?
Not sure what i did, didn't do or did wrong? But we'll she if the bitch will pass the dam MOT this weekend after another day fiddling on friday, so here's hoping...
  • Replies 9
  • Views 1.7k
whats the rotor arm and dizzy cap like? give the rotor arm a lil clean with some emery paper.
also worth checking the plug gaps, make sure they are all the same,
then wehn the cars running, whip each lead off and check to make sure the engine tone changes, if it doesnt then that cylinder was missing, so then you can check if that lead is actually sparking, replace it with a working lead off another working cylinder if neccessary.
if its getting a decent spark, your replaced lead with a working one and plug gaps fine, get a compression test done on the cylinders.
and get some pics you deuchebag =D
mk2 'quin ftw
I usually swear at it till it works again :lol:
We needs pics too ;)
haha thats what i do!, tends to work tho :lol:, or if that doesnt get a hammer hit it a few times! job done
I brought a 89 square back from the dead, a £90 non runner. remember needing new leads along with a fair few other bits and pieces. Plastics and rubber parts don't improve when a car is motionless for years think mine hadn't run for a good 18 months so it has taken replacement of many bits to get it running good if a bit rich on the weber carb conversion.
Can't believe I only just bought a new dizzy cap and rotor arm after 2 years which has definitely helped things.
Get yourself onto the engine/transmission section and use the search function with my name and you'll no doubt find the legacy of issues that I have had since joining CP.
Good luck
Edited by MacColl
Make sure you've put the leads back in the right order. IIRC firing order is 1342. It may be you have a couple swapped and its running on 2 cylinders. Its also possible one of your new plugs or leads is dodgy, even if they are new. Take off dizzy cap and make sure its nice and clean inside.
Well i figured out why she was only firing on three, i tried everything from swearing at her, to having a sulk, smoking too many cigarettes then finally noticed that the fourth lead was faulty...
I cannot belive bosch would make such a mediocre part. I replaced this lead with one i had removed and bugger me she's sweet as a nut!!
I also replaced the new plugs with the original plugs after i'd cleaned em i thought these ones looked better??
The new ones have only one metal thing at the tip and the originals had three??
Dunno if this makes a difference but i think she sounds sweeter with the three point types?? Any comments as i know nothing about them...
Also i took her for an MOT, i was pretty pissed off yesterday - last night, calmed down now and can the light at the end of the tunnel again. I cannot believe the oily man can even see the gaitor thing he said was missing i can't see it, my friend Chris can't and my Dad can't so what you talking about oily MOT dude?? Maybe that's the point i can't see what's not there and having no idea what's supposed to be there don't know it's not and therefore have no idea what it is or where it's supposed to go.
Anyway re-test not booked yet but she'll make her proper road debut soon!!
Sorry still no pics but i'll remember for next time...
:lol: if you can get a multimeter in the future it is really useful for checking the ressistance in the HT leads. It should show a ressistance of 30,000ohms for every metre or roughly that, and if you get a lower value or like no value at all then you know one of the leads has a gap in it and is fucked. Glad you sorted the running out though :thumbsup:
The spark plug having three tips is just for long-life. The spark is basically shared between 3 pins instead of one, so in theory it will last '3 times as long' before one of the pins gets eroded too much by the high voltage and sparks travelling from it. Having only one shouldn't effect the effectiveness of the spark, so long as you gap them properly.
And as for this gaitor you failed on, what exactly was it? Can you read it off the failure sheet?
It wasn't a CV boot, I'm guessing?
Edited by CWA
Says Nearside Steering Rack Gaiter split/missing...
I've looked everywhere on the nearside nothing checked the offside as maybe he wrong nothing??
Does anyone know if he means ctr steering rack gaiter but the mot system won't allow ctr??
Anyway i've reattached the center steering rack gaiter properly with tie wraps both ends and it's not missing split or moving.
So Oily MOT Dude we'll meet again in the morning and if this gaiter thing is still missing or split then we's gonna have words!!
:lol: haha good lucky buddy. afraid i can't really give you any more info.. except that i'm imagining there should actually be a gaiter on each side, as there will be connections in the middle of the rack for the steering system etc. if you sorted out the gaiter from the nearside though and it's all fixed soundly then you should be orite.
let us know how you get on!
