Will this ET fit my bread van?
Hi I've seen some bbs 13" rim, 6J ,ET33. If I put on 155 tires (about the widest I want to go) would those fit under the arches of my 40mm lowered MK2F bread van? If I'm right does the smaller offset mean that they'll poke out 5mm more on each side (given that the standard is ET38?
Cheers Guys
Nathaniel
  • Views 1k
They should fit fine. You may need to fold the arch lips back on themselves on the back but you won't need to flare them or anything. I doubt you'd even have to do that much tbh.
Yeah they should be fine. I'm running 185/55's on mine with that offset. Why do you only want 155's on there? I would put at least 165 if not 175.
Ok Cheers guys, as long as that offset doesn't bugger things up I think I'll bid on them.
I was running 145s before and loved getting the same fuel economy as a diesel car AND driving everywhere in the snow with no problems. Wide tires are great if you only ever drive on dry perfect tarmac. Skinny tires don't stop me driving like a loon. :)
175 is hardly wide!
