Should I go for Ported or Sealed?
Putting my sub in next week as I'm on mid-term break, just wondering if I should go with a ported sub enclosure or sealed?
Sealed seems to be slightly cheaper and I've looked around the net for some advice. People are saying smaller cars go better with sealed...
Any suggestions? Thanks
  • Replies 17
  • Views 1.4k
i have always personally preferred ported goes louder and you can tune nice and low
ported every time. means u can feel the music as well as hear it! :biggrin:
Thanks, I was told to get ported but sealed was supposedly better for smaller spaces. I will be using my boot space a lot, should I still go for the ported?
sealed.....for real low bass!!!!! :nod:
if you need the space go for sealed.still sound quality with 1000wrms
for REAL low bass ported and tuned to 20-30 hz it will rip your insides out
you can still go ported with a small box but it has to be tuned correctly and you have to take the displacement of the sub and port into account
I need to make my own ported box for that right? I've found two on ebay so far ...ported £21.98 and sealed £16.98 ...sealed is smaller. got a few answers on here now, will probs go for ported. Anyone got a sub in their 9n3??
not neccessarily it all depends on the volume of the box as if it is too small the port length may not be achieveable without taking to much volume out of the box therefore reducing box volume which in turn increases tuning
to help you design a good ported box use this program
http://reaudio.com/speaker_box/LPort_Box_Calc.html
firstly type in the size of box you want
then adjust port width and length accordingly to achieve your desired tuning
Edited by TROUBLESTARTER
ported!
Is this one a ported or sealed box?
sealed
i have a port and a plug so i ican plug it up if i iwant.
i take it you have a vibe then
ah are they the only ones? i take it your not amused :lol:
ahh guys, I went for the ported on ebay, received it today and its bloody sealed! Going to message the seller now. My friend says hes got a port though, shall I not bother and just use his port?
sealed is better anyway lad.
i had 4 12inch subs in the rear seat of my old mini.
liquid injured hearing , i think thats what the doctor called it.
the vibe stuff is ok
the only advantage sealed has over ported is the box is more forgiving if it is slightly over or undersized
ported needs to be correctly built for the sub and tuned to peak at a certain level
but ported in a competition vehicle for example will always hit an spl meter harder and louder than sealed
sealed in my opinion is just a compromise on sound compared to a well built and correctly tuned ported box
