Pioneer DEH-P5730MP
In very good condition, £50. P+P will be £8 First class recorded. You'll need your own ISO cable, they're around £3 on ebay.
Whether you lean towards pure radio entertainment or full-blown multimedia, this CD RDS tuner takes you beyond sonic nirvana. Connect extra amps and speakers to the 2 RCA pre-outs and create the in-car sound system that truly rocks. Your DVD player, DAB tuner or multi-CD player hooks up to the IP-Bus control. As up-to-date as you are, you will want to connect your iPod® through the optional adapter to enjoy your digital music collection. The Sub-Display Output lets you confirm basic tuner info on your existing car display.
Specifications
Key features DEH-P5730MP
LCD display
Multicolour display
VW-red key illumination
Pop-Up Rotary volume
Disc naming (8 char.)
Source Level Adjustment
Cellular mute
ISO-connector ready
Main features DEH-P5730MP
Display illumination LCD
Sub-display output Yes
Cellular telephone auto muting Yes
iPod® adapter ready Yes
No. of Radio Presets 24
Max. output power (watts) MOSFET 4 x 50 W
RCA Preout 2 (F + R)
Features - General DEH-P5730MP
Multi-CD Control Yes
CD Text Yes
Source TV Control Yes
DAB Tuner Control Yes
Source DVD Control EXT
External unit control via IP-Bus 2
AUX-In (with optional CD-RB20) Yes
Remote control Ready
Hard-wired remote input Yes
ISO Connector ready Yes
Rotary volume Pop-out
Front Panel Flap type (mechanical)
Removable Front Panel Yes
Flexible angle installation 0-60°
Features - Tuner DEH-P5730MP
Adaptive RDS (PI, PS, AF, TP/TA) Yes
PTY (Search and Alarm) Yes
News interrupt feature Yes
ARC FM D4Q
BSA (Best TP Station Auto Search) Yes
PNS (Pulse Noise Suppressor) Yes
BSM (Best Stations Memory) Yes
Features - CD player DEH-P5730MP
Oversampling digital filter 8x
D/A Converter 1- Bit
Fast forward/reverse Yes/Yes
Track Search/Scan/Repeat Yes/Yes/Yes
Track/Manual search Yes/Yes
Random Play Yes
Last position memory Yes
Disc Title Memory Yes
CD Text Yes
CD-R Playback Yes
MP3 Yes
Windows Media™ Audio Yes
CD-RW Playback Yes
WAV Yes
Features - Audio / Amplifier DEH-P5730MP
Continuous output power (DIN45324, +B=14.4 V) 4 x 27 W
EEQ Yes
5-mode preset equaliser Yes
Custom preset equaliser Yes
3-band parametric equaliser Yes
Source Equalisation Memory Yes
Selectable Loudness Yes
Selectable FIE (Front Image Enhancer) Yes
Loudness Yes
Source Level Adjuster Yes
Fader Yes
Specifications - FM DEH-P5730MP
Frequency range 87,5 - 108 MHz
Usable sensitivity (75 ohms) 8 (0,7) dBf/µV
S/N ratio 75 dB
Frequency response 30 - 15.000 Hz
Stereo separation 45 dB
Specifications - MW DEH-P5730MP
Frequency range 531 - 1.602 kHz
Usable sensitivity 18 µV
Specifications - LW DEH-P5730MP
Frequency range 153 - 281 kHz
Usable sensitivity 30 µV
Specifications - CD DEH-P5730MP
Frequency Characteristics 5 - 20.000 Hz
S/N ratio 94 dB/1 kHz
Dynamic range 92 dB/1 kHz
Specifications - General DEH-P5730MP
Chassis size (W x H x D) 178 x 50 x 157 mm
  • Views 172
Provisionally sold!
