Moving front door speakers to the rear
Hi guys, I'm a bit confused on what to do. after deciding on amping my components to the rear of the car / the rear card walls (its a 3 door 6n2) I'm worried that I wont be able to hear much of it as its in the back and behind the seats. Also when I'm in a call from the headunit bluetooth, i think that i wont be able to hear the caller and might have to have it really loud to hear the caller. (i plan to remove the door speakers - front) any advice would be good.
  • Views 759
bump!
why would you want to remove the fronts if theres a good chance you will miss them?
keep them in and run them off the headunit,add some more to the rear and amp them,rears will have more power but fronts will still give decent sound
does your headunit have four channels plus a line out?
