Headlamp washers
Genuine OE headlight washers wanted. May consider complete bumper if correctly fitted.
  • Replies 14
  • Views 1.7k
I still want these. I only want the actual washers to fit on the bumper, I've got no rear wiper so will plumb them in instead of the rear washer, so I don't want the large tank and pump, loom etc.
the wee window pump wont make them work I'm afraid, there is a 3 way vacume valve in behind the bumper and the tubing is like garden hose size!!
but if its just for looks they will pop straight on to you bumper with a wee bit of drilling. :-)
I do want them for looks, but if they're there, they've gotta work!
So looks like I need the lot, anyone got any of the bits?
I got a full kit for a GTI Bottle, pumps, pipes and the jets not sure if it could be modded to fit a mk3?
Thanks Eddiie, but it's the proper mk3 jets I'm after in particular, getting them working (with whatever other bits) can come later!
BUMP
I may have a full genuine set for sale, will know for the weekend £145 posted - my friend has 1st refusal on them at the mo.
includes:
left jet x1
right jet x1
mounting bolts x4
mounting washers x4
3 way valve (to jets) x1
90 deg adaptors (valve pipe to jet)x2
7.5L tank and lid
obsolite headlamp washer pump & grommet x1
standard washer pump but you can use your own to be honest.
in bumper pipework and clamps
golf headlamp washer wiring loom with correct relay (no33) and relay base plate for a polo ( just needs the wires extended to the battery and a conection link to the existing pump)
1 wiring up diagram with photos
home made cardboard Bumper cutting out template x1
basically everything except 1 small section of rubber hose from the pump to the valve but thats easy onough to get from VW or B&Q!
You've got my hopes up now! All working and no damage? Got any pics? If your mate doesn't have them let me know and we'll do the deal!
sorry due ross wants them.
Bugger! If he changes his mind, I'll definitely have them.
Still wanted.
I got mine all set up at the weekend... You so need to source a set dude! I used a whole 7.5l container in less than a day!
I need these in my life. :lol:
Another nudge up.
