6n front wing change
Hey I need to go grab a pair of wings off a 6n on my way home from work, need to know what tools il need, where the fixings are or a rough guide to get them off, can they be removed with wheels on? Loadsa people musta done this could wrk it out for myself but rushed off my feet at work and gonna be time limited later!!
Thanks in advanced
  • Replies 10
  • Views 1.9k
take of the plastic arch above the wheels mate i think there are 2 bolts under there, and there some running under the bonnet on top, thats all i can remember pal, 10mm or a 13mm socket iirc
Yeaa there's some m6 bolts in engine bay and torx screws on arch liner, I know it hooks in down by door hinge but how does it attach at sil? Do u have to take indicator out?
ok, i dont know sizes but u need to undo all the bolts in the bonnet, and the little black one by the headlight! then remove the arce liner then theres a screw holding the bumper to the wing and two bolts there aswell (if bummper off it makes it alot easier) then theres two bolts holding it on to the bulkhead (can see them if you remove the indicator) then just pull the wing from the top unhook the wing by the sill (the hooks bend really easy so dont worry!) then carefully manuver it out!
sweet, how longs it gonna take to get the pair off?
Theres two bolts on the inside of the bumper aswell. You may have to take the bumper of to get to them.
All the bolts are 10mm.
yep i thought so! i can do it in about 10 mins each side thats getting the tools out and bumper off! going steady
How do I get bumper off? Taa
bumper take grill off and surround, and maybe lights not sure there are 3 screws across the top ( i had to drill these out, and 2 on each side where the plastic arch is pal i think,
u dont need the lights out, but there is 2 torx 25's on the top either side of the inside of the lights and also one either side of the small lower vent and also one either side of the middle grille :)
doneeeee sorteddd piece of cake no issuess :) except stupid muddy scrapyards haha.
one wing was all dented tho so only got one :(
