Safety devices roll cage
Bit of a Long shot this but does anyone know the value of a full cup car rollcage made by safety devices?
in good condition but will require mounting brackets?
  • Replies 29
  • Views 2.9k
I always think rollcages are more dangerous without the correct seat harnesses as all passengers and yourself are faced with bare metal, unless of course your intending to use it for trackdays.
good for you
What? Of course you are faced with metal, the whole car is made from it. A properly installed roll cage is far safer than the stock shell if you were to roll the car. Why does it matter if it's track days or road use? If anything, improperly installed harnesses are the most dangerous thing; specially when people just attach the harnesses to their rear seatbelt mounts at a silly angle.
Harnesses without a cage is a lot more dangerous lol. With a proper seat belt on you won't really go anywhere in a roll anyway
Specially if something like this happens! :paranoid:
http://www.schmiechen.com/photos/NoRollBar.../variant/medium
foam. done.
What do the comments above have to do with the value of a roll cage?
I dont want personal opinions on safety etc just how much there worth{no offence meant}
^^^ Agreed.
Keep it on topic please.
Safety devices rollcages are quite expensive iirc. I'm good nick, its probably worth £800+ but thats just a guess.
Thanks for that i thought they were worth a few quid but i didnt expect that much :-D
New OMP cages for MK3 are 487 for bolt in and 675 for weld in.
LOL justice
baring in mind that if its from an actual cup car then it's probably been bent out of shape once or twice an there's no mounting plates, I'd prob say £250-£350. £800 is ridiculous, you could buy a brand new custom cage for that.
I paid less than £800 for my brand new SD cage with all mounting hardware, a lot less. They've gone up a fair bit since then as it was years ago.
I was thinking back to a thread a while ago on cages and the best one to get. Did say it was only a guess anyway and yeah, probably been 'needed' once or twice in its life. Weld in cages are better yes?
Custom Dubz in Aberdeen make these if i remember correctly :)
you should be welding in spreader plates, and you can either weld the cage to the spreader plates, or weld captive nuts into your spreader plate and bolt the cage into them.
drilling a couple of holes in a suspension turrent and just whackin a bolt in is silly =P
Cheers Saf. I know what I'm looking for now :)
brand new cup car cages are £675, inc mounts and bolts and VAT etc.
2nd hand with no mounting hardware, i'd be saying £250ish
also worth noting, that OMP don't make a weld in cage for a mk3, OMP's mk3 is what we'd call a mk5. You need a mk1 polo cage from OMP to fit a mk1/2/3
er, Safety Devices in Suffolk make Safety Devices roll cages. Or do you mean that company in Aberdeen make roll cages in general?
Although to be fair I think SD subcontract out manufacturing outside the UK these days.
I can buy a brand spanking new, bolt in OMP roll cage for £540 + VAT and Delivery (demon-tweeks)
Use that as a basis for it, so for your safety devices one, I'd stick it on the market at about £250-£300
The 6n cup cars all had OMP weld in cages (£740)
Edited by majic79
iirc they're made in poland
to be fair, the SD cages for a mk3 polo are far better quality than the OMP cages for mk3 polos.
You could spend ages arguing about which roll cage is better than the other - as long as it's certified by the MSA or FIA, it doesn't make much difference, the only thing worth paying for is weight saving. If it stops the car staving in in a big enough crash, it's done it's job, wether it's OMP or SD or Sparco or A.N.Other brand
Personally I don't really like any bolt in cage, they are nowhere near as strong as weld in cages, but you can't take a welded cage out afterwards - you win some, you lose some.
And I don't know the guy, no idea about the car it's come out of, the only cars I know anything about are the 6N Group N homologated cars - so my advice was based on the only information to hand.
I know what you are saying but having compared the two the SD cage looks much better made and fits the car better. Also I know someone who bought a brand new OMP cage a few years ago and ended up having to re-make all the weld-in load spreading plates himself as the ones that came with the cage didn't fit very well. Just means more work for whoever fits it. But my SD cage is back from when they were still being made in the UK so I couldn't really comment on the quality of SD these days.
