front shock/struts
as title need them as soon as poss i want them really by the weekend and also need to have good bearings aswell
thank you
  • Replies 11
  • Views 1k
I've got some, they came off a mk2, but theyve got the same part number
is it excactly the same as the mark 3 what the wheel bearings like
Just had a feel at the bearings and they feel ok. Yeah they are the same as mk3, they were taken off a mk2 for coilovers. The only difference is the steering arm is a different design, but the same angles etc.
so would it matter about the design will it fit on mine and how much u want posted
yeah should fit a mk3 no problems. are you just wanting the struts with the dampers in? or with springs?
just struts with hub and are they uprated dampers no springs thanks
no they are just standard dampers. 25 collected 40 posted
is that both for 40 and ill have the dampers too
got 1 bare strut and 1 still with the hub bearing etc in them £25 + postage?
means you can fit new bearings in them or do them up before fitting them.
can you get them to me by sunday
yeah both for 40. wont be able to get them to you for sunday. too short notice to get them packed and picked up.
